HAL.Port.OpticNotCompatPort
Description
An optic module of a particular type has been inserted into a port on this platform with which it is not compatible. The optic module can not and will not work in the specified port.
Remedy
Remove the incompatible optic from the port and replace it with one that is supported in that port.
Severity
Warning
Message Text
The %optic% optic module is not compatible with this port on this platform - please remove it from port %slotPort%.
Message Parameters
Name Type
optic String
slotPort SlotPort
Applicable Platforms
